flywheel for Kokusan ignition system http://ducatipaso.org/forum/viewtopic.php?f=13&t=3714 |
Author: | jpitz31 [ Mon Nov 09, 2009 2:51 am ] |
Post subject: | flywheel for Kokusan ignition system |
Hello, I made the change to the Kokusan ignition systemm I am looking for the newer two pickup flywheel. Does anyone know which flywheels are compatible with a 1990 750 sport. There is a 900 ss flywheel currently on ebay. Just wondering about compatibility? Thanks Joe |
Author: | guzzitech [ Thu Nov 12, 2009 6:28 am ] |
Post subject: | Re: flywheel for Kokusan ignition system |
900ss flywheel will work. You may have to swap the flywheel holder if it is an early Paso with a coarse spline flywheel hub. |
Author: | paso750 [ Thu Nov 12, 2009 10:57 am ] |
of course it should be from a carbed 900SS not a SSie |
Author: | Tamburinifan [ Fri Nov 13, 2009 1:15 am ] |
Do you have a 6-spline or multi-spline crank on yours? 750 Paso cank-flywheel works w Kokusan. I would download spare parts list f various models fr years like yours. There are several parts that need to match, f e w another flywheel, starter gear/sprag may be different. Alternator is another issue. |
Author: | paso750 [ Fri Nov 13, 2009 12:14 pm ] |
Author: | Tamburinifan [ Fri Nov 13, 2009 6:01 pm ] |
Author: | jpitz31 [ Thu Nov 19, 2009 12:19 am ] |
Thanks All for the tips. As soon as I can get this sucker running properly again I will post some pics. Joe |
Author: | jpitz31 [ Sun Nov 29, 2009 7:28 am ] |
Hello All, I have a related question on the kokusan flywheel. There are serveral flywheels post 1998 on ebay. But I cannot find any pre 1998 flywheels. I have the 4 pickup flywheel. What would be the feasibility of milling off the two upper pick-up points and leaving the two lower pickup points on the flywheel (as show in the maintenance manual when the #1 cylinder is at tdc) I can locate another 4 pick-up point flywheel from a paso. I have been running the 4 pickup point flywheel with the kokusan ignition and I think this could be causing my high speed bog. Thanks Joe |
Author: | paso750 [ Sun Nov 29, 2009 9:21 am ] |
note the flywheel is balanced so removing parts will unbalance it causing vibration and some damage sooner or later. |
Author: | Tamburinifan [ Sun Nov 29, 2009 2:08 pm ] |
I have 2 pre -98 flywheels f Kokusan to sell. Where are you located? Do you have 6 spline or multispline crank? Milling would need rebalancing to work as Gerhard states. |
Author: | jpitz31 [ Sun Nov 29, 2009 11:44 pm ] |
Hello Tabmurinfan I have the 6 spline crank. You can PM me with the price and shipping. I have a bid on a flywheel that paso750 found on ebay. If it does not go through I will more than likely purchase one from you. Thanks Joe |
Author: | jpitz31 [ Thu Dec 31, 2009 1:53 am ] |
Hello All, I changed out the old flywheel with the new one I purchased on ebay and that fixed my high speed miss. So the Kokusan ignition change out was successful. After all of the troubleshooting I went through it was really nice to get the bike running properly. So I decided to tear it completely down and clean it up. I did read a bit of interesting article on guzzitech.com on proper testing of the dual pickups. Here is the link: http://www.guzzitech.com/Bimotacagiva/P ... retch.html I will be posting some pics of my progress. Thanks Joe |
Author: | Tamburinifan [ Fri Jan 01, 2010 1:33 am ] |
Great job & thx f sharing! ![]() |
