| 16 in rear wheel solution? http://ducatipaso.org/forum/viewtopic.php?f=13&t=3727 |
| Author: | ottovalvole [ Sun Nov 15, 2009 12:51 am ] |
| Post subject: | 16 in rear wheel solution? |
Hi As everybody knows there`s a problem to find a desent rear tyre for our beloved 750 Sport and Paso. I have beeen thinking, is it possible to make the egde of the rim taller by welding and machining, and a 17 in tyre could be used? Does someone know if it can be done? I think the Oscam rim is much better looking than the newer 3 spoked SS rim is. It disturbes the design of the bike if you convert to 17 in SS rims like many do. That`s my opinion. Also, does somebody knows if a 16,5 in tyre could be used? Regards Ottovalvole |
| Author: | paso750 [ Sun Nov 15, 2009 9:01 am ] |
| Post subject: | Re: 16 in rear wheel solution? |
Hi, look in the forum and use the search function and you will find it all. viewtopic.php?f=1&t=3678 G. |
| Author: | persempre907 [ Sun Nov 15, 2009 9:43 am ] |
| Author: | ottovalvole [ Fri Nov 20, 2009 10:43 pm ] |
