| flat battery http://ducatipaso.org/forum/viewtopic.php?f=13&t=4259 |
| Author: | jakarate1 [ Mon Aug 23, 2010 5:21 am ] |
| Post subject: | flat battery |
Hi, my 750sport has a flat battery;can i charge the battery without removing from the bike |
| Author: | ducinthebay [ Mon Aug 23, 2010 5:36 am ] |
| Post subject: | Re: flat battery |
Yes, but you need to add a charging connection to the battery. If you buy a trickle charger, most of them come with a pigtail that you can attached to the battery and simply plug in when not in use. I keep most of my bikes on a battery tender when I'm not using the bikes much. I find the Sport to be really good on batteries. If your battery is several years old, it may just need to be replaced. Cheers, |
| Author: | jakarate1 [ Mon Aug 23, 2010 5:43 am ] |
thanks,the charging connection will i have to buy from a bike shop or can i get from a retail store?jas |
| Author: | higgy [ Mon Aug 23, 2010 9:31 am ] |
Any automotive supply can get you a pigtail for a trickle charger............. |
