It is currently Sun Sep 28, 2025 9:31 pm
 Post subject: 900 ss/sl engine
PostPosted: Thu Sep 08, 2011 8:15 pm
hello, does anybody know if the 900 ss/sl engine from 1993 wil fit the 750 sport frame from 1990?
thanks,..
ducati pantah 600 racer 1980
ducati 750 sport tricolore 1990
ducati 750 sport racer 1988
ducati 750 sport parts bike 1990
ducati 1100 evo hypermotard
 Post subject: Re: 900 ss/sl engine
PostPosted: Thu Sep 08, 2011 8:20 pm
lots of entries on the subject,use the search grasshopper :fart:
and add your general location to your profile :beer:
it just could be you have a neighbor has just that sorta thing in their stable :thumbup:
PostPosted: Fri Sep 09, 2011 1:38 am
Yes, it will fit if you have the 3mm spacers between the frame and engine on the right hand side. Use the SS swingarm, as the pivot pin is different. Drops right in. Been done several times. As Higgy points out, hit the SEARCH button on the header of this page and find the references and details.
PostPosted: Fri Sep 09, 2011 5:07 pm
You will also need a complete exhaust system and probably some modification to the ignition. I'm not quite sure what a '93 900 ss has ignition wise.
Greetz (groet)
Joep
