| Rare C/S sprocket http://ducatipaso.org/forum/viewtopic.php?f=13&t=5042 |
| Author: | ducinthebay [ Wed Sep 07, 2011 2:26 am ] |
| Post subject: | Rare C/S sprocket |
Not mine, nor do I know the seller. http://cgi.ebay.com/ebaymotors/Cagiva-D ... _500wt_956 Giant offset front sprocket for early models that didn't have the 3mm shims between the motor and the frame on the right side. Also good for running 180 -16" rear tires. Check your chainline if you buy it. Cheers, |
| Author: | paso750 [ Wed Sep 07, 2011 7:40 am ] |
| Post subject: | Re: Rare C/S sprocket |
I had one of those and the offset is way more than required even with a 180 tire. At least on a Paso 750 that is. They are not that rare btw. I ordered a new one from http://www.motorrad-tuning-zubehoer-tei ... j.-1987-na Getting it was no problem. They have them in 14 an 15 teeth. Price is €32-34 ($45-49). G. |
