It is currently Sat Jun 20, 2026 10:56 pm
 Post subject: Ignition hiccup
PostPosted: Fri Oct 14, 2011 3:02 am
The Sport is running better than ever. I got new o-rings on the intake manifolds and balanced the carbs (36 Dells) I got up to 120mph last weekend, and just generally had a great time.
But the bike has developed an odd new malady. It hiccups about every 4-6 minutes. At constant throttle, or even accelerating, the bike just misses a few strokes, then picks right back up. Its like the ignition just shuts off for a few revolutions. Haven't noticed it before, but now its rather constant. Like some playing with a light switch.
I plan on taking out the ignition pickup (only one on the Magnet Marelli 2S system) and cleaning it up just to make sure its working. I've heard that cleaning off those shim washers on a regular basis is a good idea also, as they set the distance of the pickup.
Any other ideas of what I should go look at while I'm staring at it?
Thanks in advance.
 Post subject: Re: Ignition hiccup
PostPosted: Fri Oct 14, 2011 5:41 am
Had a similar problem on the 906. Turned out to be a combination of the ignition switch and the wiring to the module. In the end I replaced all the terminals at the module and the switch. Hasn't missed a beat since :beer: :beer:
PostPosted: Mon Oct 17, 2011 7:06 pm
Too bad... Is it on both cilinders? Did you by accident disturb some other system (electrics) with the last repairs?
Hope you will find it soon...
Regards Joep
PostPosted: Thu Oct 20, 2011 3:46 am
Yeah, its both cylinders.
And yes, I was fiddling with the connectors by the ECU.
I was putting in a breather box, and pushed the wires around alot. I guess I'll go back and check the connectors. Seems likely.
Thanks,
