It is currently Wed Mar 11, 2026 4:20 pm
 Post subject: renovating 750 Sport forks 1989
PostPosted: Mon May 07, 2012 8:48 pm
1989 Ducati 750 sport, absolutely standard and mint. need to replace fork bushes. Where to get the parts from or a reputable company to renovate? wish to retain original. any help. uk.
 Post subject: Re: renovating 750 Sport forks 1989
PostPosted: Tue May 08, 2012 7:13 am
Maxton do upgrade work on Marzocchi's but not cheap.
PostPosted: Tue May 08, 2012 9:48 pm
Many thanks.
Maxton have a fantastic reputation and I'm
Amazed that I had not thought of them earlier!!
Have requested quote... Will post here when I get a reply.
My bike is standard, mint & getting rarer each year.
PostPosted: Wed May 09, 2012 9:06 pm
Check your local Ducati Dealer you will be amazed what they still have hidden away.
Also check this site out http://www.twowheelclassics.co.uk/ they may be of some use to you.
PostPosted: Wed Jun 13, 2012 12:44 am
After a long discussion with the guys up at Marzzochi North America in Valencia California ( 1 661-257-6630) about my 90 750 Sport front forks they did a little research for me. Called me back about a week later and informed me that the bushings used in these forks are the same as used on the early Monsters. part no. 538028>B. I ordered two sets from them, had them installed and they have worked perfectly for a little over 800 miles now.
At the same time I ordered a set of progresive rate springs from Hyperpro in Werkendam, Holland, http://www.hyperpro.com +31 183-678867. Forkspring 0205 X, Part no. SP-DU07-SWB003. These were installed at the same time as the new bushings and naturally a new set of fork seals.
The front suspension is smooth in both compression and rebound. I have not had a case of bottoming out since I undertook the rebuild. No leaks, no squeaks, no problems! :)
John Hardy
San Diego, CA
PostPosted: Wed Jun 13, 2012 2:03 am
Nice summary and great information. Thanks for the post. One of the reasons that this site is so good, lots of contributors.
Phil
