| renovating 750 Sport forks 1989 http://ducatipaso.org/forum/viewtopic.php?f=13&t=5372 |
| Author: | vincento [ Mon May 07, 2012 8:48 pm ] |
| Post subject: | renovating 750 Sport forks 1989 |
1989 Ducati 750 sport, absolutely standard and mint. need to replace fork bushes. Where to get the parts from or a reputable company to renovate? wish to retain original. any help. uk. |
| Author: | 900streetfighter [ Tue May 08, 2012 7:13 am ] |
| Post subject: | Re: renovating 750 Sport forks 1989 |
Maxton do upgrade work on Marzocchi's but not cheap. |
| Author: | vincento [ Tue May 08, 2012 9:48 pm ] |
Many thanks. Maxton have a fantastic reputation and I'm Amazed that I had not thought of them earlier!! Have requested quote... Will post here when I get a reply. My bike is standard, mint & getting rarer each year. |
| Author: | englishstiv [ Wed May 09, 2012 9:06 pm ] |
Check your local Ducati Dealer you will be amazed what they still have hidden away. Also check this site out http://www.twowheelclassics.co.uk/ they may be of some use to you. |
| Author: | jrhardy [ Wed Jun 13, 2012 12:44 am ] |
After a long discussion with the guys up at Marzzochi North America in Valencia California ( 1 661-257-6630) about my 90 750 Sport front forks they did a little research for me. Called me back about a week later and informed me that the bushings used in these forks are the same as used on the early Monsters. part no. 538028>B. I ordered two sets from them, had them installed and they have worked perfectly for a little over 800 miles now. At the same time I ordered a set of progresive rate springs from Hyperpro in Werkendam, Holland, http://www.hyperpro.com +31 183-678867. Forkspring 0205 X, Part no. SP-DU07-SWB003. These were installed at the same time as the new bushings and naturally a new set of fork seals. The front suspension is smooth in both compression and rebound. I have not had a case of bottoming out since I undertook the rebuild. No leaks, no squeaks, no problems! Cheers, John Hardy San Diego, CA |
| Author: | ducinthebay [ Wed Jun 13, 2012 2:03 am ] |
Nice summary and great information. Thanks for the post. One of the reasons that this site is so good, lots of contributors. Cheers, Phil |
