ducatipaso.org • View topic - FCR fitment
It is currently Sat Feb 28, 2026 10:23 pm
 Post subject: FCR fitment
PostPosted: Tue Dec 31, 2013 1:41 pm
Guys are the racked FCR's supposed to fit in the 750/900. Just pulling the Mikunis out this afternoon to replace with FCR's on my 900 and they do not fit up. Theey hit the battery tray straps before they fit into the rubber mounts properly. I've been searching but haven't come across it yet. I expected they would fit exactly where the Mikunis were but the float bowls hit.
Not a big issue for me as I was tossing up removing the battery tray for bigger air filter clearance but it would have been nice if they did fit so I could try with some old foam filters. Are the 750 motors just that bit shorter enough that they fit without hitting.
 Post subject: Re: FCR fitment
PostPosted: Tue Dec 31, 2013 11:07 pm
model: other
Alternate fitting suggestion
2013-09-15 13.24.15a.jpg [199.1 KiB]
Downloaded 368 times
2013-09-15 13.23.56a.jpg [182.13 KiB]
(Andrew2 please note RED cable ties :lol: )
Peter
PostPosted: Wed Jan 01, 2014 6:02 am
:shock: wonderful job you've done there Peter.
Andrew
PostPosted: Wed Jan 01, 2014 11:39 am
I was originally looking for splits but cost was a big factor. Couldn't find any second hand and by the time I got a full kit with throttle, manifolds, carbs and filters new it would have been close on double the cost of the racked set I have as I already had the Mikuni manifolds and got a second hand racked set with everything.
Battery tray is gone now. Just tossing up filter options and whether I should move the cross brace forward to get bigger filters with better bellmouths in. Not sure if it's really worth the effort.
How well do those mesh filters work, I have read they are not so good for flow but would probably clear the crossbrace.
PostPosted: Thu Jan 02, 2014 12:25 am
model: other
PostPosted: Thu Jan 02, 2014 12:58 am
model: other
PostPosted: Thu Jan 02, 2014 11:42 am
model: other
year: 1999
Beautiful work!
Maybe K&N pods would flow better than the foam pods. Might be an option for a street bike. Maybe using a Lithium battery might free up some space for bigger filters.
2013 M1100Evo Street
1999 M750 "Scrambler"
2004 GSXR750 Track
PostPosted: Thu Jan 02, 2014 11:51 am
model: other
year: 1999
2004 GSXR750 Track
PostPosted: Sat Jan 04, 2014 10:44 am
