ducatipaso.org • View topic - 1990 750 Sport fork oil
It is currently Mon Sep 29, 2025 2:56 am
 Post subject: 1990 750 Sport fork oil
PostPosted: Fri Feb 14, 2014 4:01 am
Thinking about replacing my fork oil, so I need a little help deciding how much oil to buy to refill both of my forks. Also wanted to know if you guys are running 5wt oil on your bikes. And, does anybody know exactly how much oil goes in each fork?
Any help would be greatly appreciated. Thanks
 Post subject: Re: 1990 750 Sport fork oil
PostPosted: Fri Feb 14, 2014 5:43 pm
You`ll need approx. 350cc per fork leg but how much oil goes in is not that important as the correct airgap. That`s 150mm (to the liner). All info that is mentioned in the manuals btw...
PostPosted: Fri Feb 14, 2014 7:19 pm
Thanks G. I did see the 150mm airgap, and just wanted to confirm that was still holding true these days.
PostPosted: Fri Feb 14, 2014 10:55 pm
model: other
Have replaced mine twice now in 2 years, used Repsol 15W first time and 300cc per leg on advice from my mechanic, and this time Belray 15W and 360cc which gave the 150mm air pocket as per the manual, I had replaced the fork seals so it was a complete fork legs off and cleaned out dry fill.
The strange thing is can't feel any difference in how the forks are working with the extra fluid, have a black cable tie on one fork leg to check travel and it is in the same position as before after road testing the bike.
And the ride is still the same, not soft or harsh, just does what is it meant to.
Peter
PostPosted: Sat Feb 15, 2014 5:00 am
Thanks Peter
My local shop said to use 5W and I thought I should use at least a 10W like my othe bikes.
However, he said you get better feel using 5W because it's thinner and starts working faster. I don't know if this is true, but I'll give it a shot and see how it works out.
PostPosted: Mon Feb 17, 2014 5:19 pm
your shop is right. I`ve used 7.5 in the past as I didn't know if the fork would become to bouncy with a 5W oil.
Then I got progressive springs and those came with a 2.5 and it works fine.
As the fork already is rather stiff I wouldn`t go with thicker oil. Peter, I wonder if the fact that you`re in a hotter climate has impact on the oil and how the fork reacts to/with it.
PostPosted: Mon Feb 17, 2014 9:49 pm
model: other
It's an interesting subject, like Nunodeo I've always used 10W in most of my bikes over the years except in the various BM's which were either 5W or 7.5W or my old '78 Honda 750/4 which ran 20W :lol:
I was a bit wary when advised to use 15W thinking it would make for a very harsh ride indeed, but it is actually quite supple over bumps.
I've got a video I'll post on Dropbox or You Tube and post the link in this topic, which was a road test with a camera strapped on the frame and all you can see is the forks and the range of travel, and it is with 15W in them, I got a shock when I watched it, never realised how hard the forks really work :shock:.
We do tend to have a warmish climate, I say that laughingly as it's meant to summer here and it's raining and around 15c outside.
Peter
PostPosted: Tue Feb 18, 2014 6:58 pm
PostPosted: Sat Mar 01, 2014 7:06 am
model: other
You Tube link, test ride after fork oil change to 15W but was mainly trying to figure a reasonable place to mount the borrowed camera I had at the time.
The M1B's certainly do what they are meant too.
http://youtu.be/P8DihhXBcrM
