It is currently Tue Jun 16, 2026 7:58 am
 Post subject: Valve Advice on my 1990 900SS
PostPosted: Tue Jun 24, 2014 11:34 pm
Fellas
Without a doubt you boys know your stuff so here is the next question in my build (just had frame back from the painter & looks awesome)
I know what & where I am getting for the balance of my build (just about to press that button) but am stuck on the Top End
I will do valves, seats, guides, etc, etc (do it all whilst apart)
Was going to use OEMCycle with Kibblewhite gear as follows (obviously standard)
0926-1184 VALVE EX DUC 900 2V 38MM
0926-1182 VALVE IN DUC 900 2V 43MM
0926-1186 GUIDE VALVE IN STD DUC900
0926-1188 GUIDE VALVE EX STD DUC900
But on enquiry they dont do Valve Seats that go with these valves (I wanted to make sure the parts I ordered would fit)
Advice fellas on alternatives who can do the whole lot in one order ...
a. am I looking at the correct parts for my machine?
b. what other options are there?
c. is there a better product?
d. can I use any other brand Seats (pretty obvious but throw it in there)
Regards The Poacher
 Post subject: Re: Valve Advice on my 1990 900SS
PostPosted: Wed Jun 25, 2014 2:17 am
Whats wrong with the old stuff . I pulled mine apart at 67000k's and after measuring the shit outa everything all I could find was slightly loose ex valve guide clearance........even the rings were good. I lapped the valves and chucked it back together :)
PostPosted: Wed Jun 25, 2014 9:12 am
agree ^ valve seat change is drastic and often the head is never quite the same unless done carefully. If the seats aren't recessed badly or damaged then it's pointless changing them.
Users browsing this forum: No registered users and 27 guests
