| Valve Advice on my 1990 900SS http://ducatipaso.org/forum/viewtopic.php?f=13&t=6778 |
| Author: | The Paua Poacher [ Tue Jun 24, 2014 11:34 pm ] |
| Post subject: | Valve Advice on my 1990 900SS |
Fellas Without a doubt you boys know your stuff so here is the next question in my build (just had frame back from the painter & looks awesome) I know what & where I am getting for the balance of my build (just about to press that button) but am stuck on the Top End I will do valves, seats, guides, etc, etc (do it all whilst apart) Was going to use OEMCycle with Kibblewhite gear as follows (obviously standard) 0926-1184 VALVE EX DUC 900 2V 38MM 0926-1182 VALVE IN DUC 900 2V 43MM 0926-1186 GUIDE VALVE IN STD DUC900 0926-1188 GUIDE VALVE EX STD DUC900 But on enquiry they dont do Valve Seats that go with these valves (I wanted to make sure the parts I ordered would fit) Advice fellas on alternatives who can do the whole lot in one order ... a. am I looking at the correct parts for my machine? b. what other options are there? c. is there a better product? d. can I use any other brand Seats (pretty obvious but throw it in there) Regards The Poacher |
| Author: | Mc tool [ Wed Jun 25, 2014 2:17 am ] |
| Post subject: | Re: Valve Advice on my 1990 900SS |
Whats wrong with the old stuff . I pulled mine apart at 67000k's and after measuring the shit outa everything all I could find was slightly loose ex valve guide clearance........even the rings were good. I lapped the valves and chucked it back together
| Author: | giocast [ Wed Jun 25, 2014 9:12 am ] |
agree ^ valve seat change is drastic and often the head is never quite the same unless done carefully. If the seats aren't recessed badly or damaged then it's pointless changing them. |
