ducatipaso.org :: View topic - Leaking Neutral switch
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=13&t=7135
Author:  ridgeskimmer [ Mon May 11, 2015 7:24 pm ]
Post subject:  Leaking Neutral switch
My Neutral switch at the back of the engine is weeping oil. I have tried tightening but still leaking. Just wondering if fitting a new one will fix this and if anyone has any links to wear I might get a new one?
Many thanks
Author:  Derek [ Tue May 12, 2015 8:46 am ]
Post subject:  Re: Leaking Neutral switch
Available from Steine Dinse -
It is the same as fitted to the SS and Monster models up to 1997, so should still be available from any Ducati dealer.
Author:  paso750 [ Tue May 12, 2015 9:14 am ]
where exactly does it leak? The neutral switch is installed with a washer/shim.
In case you plan to replace that note it exists in at least two different thicknesses. You`ll need the right one to make sure your switch works correctly.
Author:  ridgeskimmer [ Tue May 12, 2015 9:43 am ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
