It is currently Mon Sep 29, 2025 6:09 am
 Post subject: Looking for wiring harness
PostPosted: Fri May 05, 2017 2:30 am
Looking for good original wiring loom for a 1989-90 900ss. I would think a 750 Sport one would work as well.
Thanks,
Randy
Randy K.
1990 900 Super Sport
Minneapolis, Minnesota USA
 Post subject: Re: Looking for wiring harness
PostPosted: Fri May 05, 2017 8:31 am
Unfortunately not. As it seems the early 900SS had two wiring looms. One for the Marelli ignition and a main wiring loom for all the rest. The 750S (most at least) and the later Supersports had a Kokusan ignition and only one wiring loom for everything.
PostPosted: Wed May 10, 2017 12:16 pm
Hi Randy i have spent much time looking for a harness for my 89 900 and found a couple on ebay which looked ok but decided to
recondition my original as i know that it basicly worked and was still reasonably soft,replaced some wires and new heatshink,
some connectors and new tape , main harness is finished and looking good, i can try to find those ebay ones if you want, cheers.
PostPosted: Mon Jun 19, 2017 10:32 am
http://www.motorcyclewiringspecialists. ... ducts.html
