| Dyna DC10-1 http://ducatipaso.org/forum/viewtopic.php?f=13&t=7419 |
| Author: | reo [ Sun May 01, 2016 9:47 am ] | |||
| Post subject: | Dyna DC10-1 | |||
Hello. Can anyone tell me where I plug connectors to the terminals on a Dyna DC10-1 coil ?? I do not understand completely if it's + and - terminals. reo
| Author: | Derek [ Sun May 01, 2016 11:43 am ] |
| Post subject: | Re: Dyna DC10-1 |
The +ve terminals should both be connected to the 12v ignition supply (I believe it is yellow/green on the 750S). The -ve terminals should be connected to the ignition modules, the vertical coil to the vertical module (grey wire?) and the horizontal coil to the horizontal module (light blue / yellow wire?). |
| Author: | reo [ Sun May 01, 2016 12:41 pm ] |
Thanks for reply. What I do not quite understand is if it is +/- on the coil. There are no marks showing who is + and who are- I also has sent a request to Dynatec but waiting for a response. reo |
| Author: | paso750 [ Sun May 01, 2016 3:52 pm ] | ||
| Post subject: | Re: Dyna DC10-1 | ||
the side with the printing is +, the side the ignition wire is -
| Author: | reo [ Sun May 01, 2016 4:33 pm ] |
Thank you for your answer. Appreciate it. As it appears on my image of the coil is missing the + mark on this. Dont know why. reo |
| Author: | Derek [ Mon May 02, 2016 8:10 am ] |
Ah! A bit tricky with unmarked coils.
| Author: | higgy [ Mon May 02, 2016 10:03 am ] |
FYI, The info is downlaodable from Dyna in the installation instructions. Section 4 basically it states the positive terminal is the one opposite the spark tower |
