| Clutch adjustment http://ducatipaso.org/forum/viewtopic.php?f=13&t=7473 |
| Author: | Maeze [ Mon Jul 04, 2016 7:40 am ] |
| Post subject: | Clutch adjustment |
Dear All, I have installed a new clutch on my 89 Ducati 750 Sport and it runs fine with it. But the clutch point is still very late on the lever. How can I adjust the point where the clutch "bites"? Thank you and Rgds, Marcel |
| Author: | Mc tool [ Mon Jul 04, 2016 8:44 pm ] |
| Post subject: | Re: Clutch adjustment |
Late ... to engage ... as in lever is almost right out before bike moves off ? , probly not a bad thing as this would mean the clutch is well bled. If the lever span is to big , if the rider has a small hand then an adjustable lever is probly the best way . https://store.bevelheaven.com/Brake-Rel ... ivot-bolt/ On this lever you can just see the end of a screw that bears on the cylinder piston , a non adjustable lever may have this screw and this may provide the adjustment you need If its the opposite , lever has to be pulled right to the bar to stop bike creeping forward you probly need to bleed the clutch better ( and they can be a proper bastard sometimes )
| Author: | Maeze [ Tue Jul 05, 2016 1:55 pm ] |
Great! It worked out with the screw! Thanks alot! |
