| loss of oil http://ducatipaso.org/forum/viewtopic.php?f=13&t=7653 |
| Author: | jakarate1 [ Thu Feb 02, 2017 7:45 am ] |
| Post subject: | loss of oil |
help please, just rode my bike for two minutes and noticed oil all over my motor and it was completely drained i think it was coming from air filter. i took of tank and looked at air filter and the bottom was soaked in oil |
| Author: | Frank.61 [ Thu Feb 02, 2017 10:04 am ] |
| Post subject: | Re: loss of oil |
Hi, Stupid question maybe, but did you change the oil previously? (overfill) Frank |
| Author: | jakarate1 [ Thu Feb 02, 2017 11:19 am ] |
| Author: | Frank.61 [ Thu Feb 02, 2017 3:58 pm ] |
Yes, most likely ... The air that normale escapes from the engine is fed back to the airfilter, if it is overfilled there is also a lot of oil that will end up in the airfilter. So gently tap off the excess oil (that's where the sight glass comes in ), clean the airfilter house and if the filter is contaminated with oil, you'll need a fresh one.Clean your engine from the excess oil and all should be ok again. Good luck, let me know if all went well. It sounds maybe a little strange but too little is always better than to much (with regard to engine oil). Frank |
| Author: | jakarate1 [ Sat Feb 04, 2017 2:42 am ] |
| Author: | paso750 [ Sat Feb 11, 2017 10:42 am ] |
