ducatipaso.org • View topic - loss of oil
It is currently Tue Jun 16, 2026 6:49 am
 Post subject: loss of oil
PostPosted: Thu Feb 02, 2017 7:45 am
help please, just rode my bike for two minutes and noticed oil all over my motor and it was completely drained i think it was coming from air filter. i took of tank and looked at air filter and the bottom was soaked in oil
 Post subject: Re: loss of oil
PostPosted: Thu Feb 02, 2017 10:04 am
Stupid question maybe, but did you change the oil previously? (overfill)
PostPosted: Thu Feb 02, 2017 11:19 am
PostPosted: Thu Feb 02, 2017 3:58 pm
Yes, most likely ...
The air that normale escapes from the engine is fed back to the airfilter, if it is overfilled there is also a lot of oil that will end up in the airfilter.
So gently tap off the excess oil (that's where the sight glass comes in ;) ), clean the airfilter house and if the filter is contaminated with oil, you'll need a fresh one.
Clean your engine from the excess oil and all should be ok again.
Good luck, let me know if all went well.
It sounds maybe a little strange but too little is always better than to much (with regard to engine oil).
PostPosted: Sat Feb 04, 2017 2:42 am
PostPosted: Sat Feb 11, 2017 10:42 am
