| sump nut or plug http://ducatipaso.org/forum/viewtopic.php?f=13&t=7654 |
| Author: | jakarate1 [ Fri Feb 03, 2017 7:24 am ] |
| Post subject: | sump nut or plug |
hi does anyone what direction plug should be turned to take out to drain oil? i am not sure if i am turning the wright way |
| Author: | Frank.61 [ Fri Feb 03, 2017 9:29 am ] |
| Post subject: | Re: sump nut or plug |
If you are looking at the nut/plug/bolt (whatever it is) you have to turn counter clockwise; against the normal direction of a clock). So, if you want to unscrew the oil plug (underside engine): lying on your back looking/eyeing against the underside you turn the wrench against the clock. Good luck, if something is not clear just ask me! Ciao, Frank |
| Author: | Frank.61 [ Fri Feb 03, 2017 9:34 am ] |
Sorry, 1 thing: be sure you pick the right plug! There are more than 1 (you need the plug which is in the middle of the engine, on the rear side of the crankcase ... the big one). Frank |
| Author: | Derek [ Fri Feb 03, 2017 9:43 am ] |
| Author: | Mc tool [ Fri Feb 03, 2017 9:14 pm ] |
And don't forget the strainer on the lower right hand side of the cases .................which turns the same way |
| Author: | bmw851 [ Fri Feb 03, 2017 10:51 pm ] |
The owners manual is readily available on the site for download, it has all the basic info you'll need to most things https://www.box.com/shared/pbgnkjcxlq Plus this thread has nearly every other thing you'll need, heaps of technical and other info viewtopic.php?f=1&t=1551 This should get you started Ducati 750 Sport Sump Plug Location.JPG [ 124.39 KiB | Viewed 15853 times ] for what your doing just think Lefty Loosy - Righty Tighty when undoing or tightening things up, sounds silly but lying on the ground working underneath a bike or car, it is easy to get confused, well me anyway... ![]() Also if you don't have one, well worth investing a in Torque Wrench. Hope this helps |
