| 750 Sport Coil Choice http://ducatipaso.org/forum/viewtopic.php?f=13&t=7714 |
| Author: | deswoodau [ Thu May 18, 2017 1:01 pm ] |
| Post subject: | 750 Sport Coil Choice |
Hi All, It appears to be time to update the old coils on my 89 750 Sport. It has a Marelli Digiplex ignition fitted with original light grey coloured coils and hard wired leads. Can anyone advise which of the following would be most suitable? Should I get 5ohm or 3ohm? Would the following be suitable? Or would the Dynatek brand be better? http://www.ebay.com.au/itm/182349079482 ... EBIDX%3AIT I've also seen the "Dynatek DC3-1 (3ohms)" or "DC10-1 (5ohms)" which would be best? Thanks |
| Author: | paso750 [ Thu May 18, 2017 1:19 pm ] |
| Post subject: | Re: 750 Sport Coil Choice |
probably none of those. The 3-5 ohms coils are for the Kokusan ignition. According to the 906 workshop manual (the 906 uses a Marelli Digiplex ignition) its coils have 0.34 ohms +/- 10% primary resistance and 3700 ohms +/- 10% secondary resistance. The best would be you`d measure the resistance of one of yours. Just disconnect one and measure the resistance between its + and - connection. |
| Author: | deswoodau [ Wed May 24, 2017 7:05 am ] |
Testing came back at 4.5ohms on each coil. This coil claims to be suitable quoted at 4ohms but isn't a brand I've heard of. http://www.ebay.com.au/itm/271621597212 ... EBIDX%3AIT Other posts claim the 3 or 5ohm Dynatek will do the job. If the 3 ohm Dynatek will provide a stronger spark over the 5 I'm thinking thats the logical choice. Unless technically neither is the suitable coil? viewtopic.php?f=1&t=5823&hilit=dynatek viewtopic.php?f=1&t=7452&p=58973&hilit=dynatek#p58973 FAQ's also state Dynateks are fine for 750's. Confused……....yes I am. |
| Author: | HighRevs [ Fri May 26, 2017 11:28 am ] |
Hi deswoodau, I'm running the 5ohms Dynatek's on mine with no problems, like you, I used this site and any information I could gather from the web and came to the conclusion that they should be fine with the Digiplex ignition. No problems yet! Your coils, like mine, should be mounted under the battery tray, lots of good airflow but right above a cylinder. From what I deduced the 3ohms do indeed give a bigger spark but run hotter compared to the 5ohms, I figured the spot they mount should get good airflow on the open road but if your doing any city or stop-start, heat soak from the engine below might warm them up quicker and reduce their life. Why I went 5ohms instead of 3ohms? It's not a race bike for me but a nice Saturday/Sunday 'spirited' speed rider. The spark increase from the 3ohms I'll never use, and personally unless you've reached the point of indexing spark plugs with a full blown race engine and 13:1 pistons I don't think you'll gain anything from running the 3's compared to the 5's. If you're having trouble starting and hoping the increased spark will help, redoing the wires and grounds from the starter to solenoid to battery will be much better. I used the Motolectric kit and that along with new Dynatek coils, new HT leads and some fresh spark plugs has made it easy to start. I also heard, and I want to stress heard; no proof was presented. That the 3ohms will wear out the Digiplex quicker than the 5ohms. No idea why or how, it's just something I read while in the same position as you, so take it with a grain of salt. Hope that helps! |
| Author: | Mc tool [ Fri May 26, 2017 11:49 pm ] |
G is right . 0.3 ohm is standard and about what mine measure out at . If yours are both 4ohm they may not be the original ones . Different ignition systems will have different dwell periods. The dwell angle is the time expressed in crankshaft degree's that the primary winding on the coil is energised. Im picking that the digiplex has a very short dwell period which means that the low resistance will allow a lot of current to flow in that short time to properly charge the primary winding . A higher resistance primary is better suited to something with a longer dwell. My Guzzi came with stock coils ( 3.5 ohm ) and a fried Dyna cdi . I checked the spec's which said the dyna would work with stock 3.5 ohm coils so I bought a new Dyna and fitted it up , the coils were smoking hot within a few minutes and so was the new dyna ( hence the fried dyna it came with ) so I logic-ed it all out and fitted a 1.5 ohm ballast resistor to each of the coils ( in series ) end of problem..............'cept being a bit OCD I couldn't leave it at that and fitted some dyna 5 ohm coils. The point is that the coils do need to be matched to the cdi, to much resistance will probly leave you with a weak spark , not enough and stuff starts getting hot . Its not just the primary resistance that effects the coil output. The primary resistance controls how much current flows ..... the dwell time controls how long that current flows for. Having said all that it beats the shit outa me how a iggy system designed to run a 0.3 ohm coil will work with a 5 ohm coil ....... but it does ..... must be something sneaky goin on in that digiplex
| Author: | higgy [ Sat May 27, 2017 5:52 am ] |
| Author: | paso750 [ Sat May 27, 2017 9:57 am ] |
| Author: | deswoodau [ Mon May 29, 2017 1:13 pm ] |
Thanks everyone for your responses……much appreciated. I'll keep you posted once I make some changes. |
