| 320 mm disc conversion with 65 mm calipers http://ducatipaso.org/forum/viewtopic.php?f=13&t=7876 |
| Author: | micap [ Fri Feb 23, 2018 4:37 pm ] |
| Post subject: | 320 mm disc conversion with 65 mm calipers |
I am doing a 17 inch conversion with custom spoke wheels, and at the same time upgrading the front discs to 320mm. I have a set of newer 65 mm bolt pattern brembo calipers, and therefore need a bracket. All I can find is brackets made for 280 mm discs, so the question is, does any of you have experience with this conversion? Drawings of a bracket, or know of any finished products? Best regards Michael |
| Author: | paso750 [ Fri Feb 23, 2018 5:16 pm ] |
| Post subject: | Re: 320 mm disc conversion with 65 mm calipers |
from the P750 FAQs: https://www.box.com/shared/lzd6kxnkgk |
| Author: | micap [ Fri Feb 23, 2018 8:48 pm ] |
Awesome. Thanks. Did not think to look in the paso section. |
