It is currently Sat Apr 11, 2026 6:19 am
[ 8 posts ] |
| Author |
Obito
Post subject: 750 Sport Oil screener Posted: Tue Apr 17, 2018 8:48 am |
Joined: Mon Apr 16, 2018 8:37 pm Posts: 16 Location: Finland
Hello everybody, I was making an oil change to my 750S and wanted to clean the oil screener/strainer. I ran into a problem where the strainer part got stuck inside the engine and only the bolt came out. Is there any hints how to get it out?
| Attachments: |
File comment: Oil screener
| Top |
Post subject: Re: 750 Sport Oil screener Posted: Wed Apr 18, 2018 7:45 am |
| paso grand pooh-bah |
Ups. It happens sometimes and it happened to a few guys on the forum. I guess the only way to get it out is with a lot of patience and long needle nose pliers.
| Top |
Derek
Post subject: Re: 750 Sport Oil screener Posted: Wed Apr 18, 2018 8:31 am |
Or maybe a pair of artery forceps
| Top |
Obito
Post subject: Re: 750 Sport Oil screener Posted: Fri Apr 20, 2018 6:16 am |
Thank you for the hints. I have to try this...
| Top |
Derek
Post subject: Re: 750 Sport Oil screener Posted: Fri Apr 20, 2018 8:23 am |
Another option:
| Top |
Post subject: Re: 750 Sport Oil screener Posted: Fri Apr 20, 2018 9:40 am |
those are good but not very strong. Since the plastic part he has to fish out has almost the same diameter as the hole it needs to be pulled through it will slip from that grabbing tool every time. Another thing to try with long needle nose pliers is stick them into the tube carefully and open the pliers while pulling out. Getting it this way might make it easier pulling it out than grabbing its edge. If the pliers are too big one could also unbend a coat hanger, shape a U, bend the tips outwards and use it the same way.
| Top |
Derek
Post subject: Re: 750 Sport Oil screener Posted: Sat Apr 21, 2018 8:02 am |
| Top |
Obito
Post subject: Re: 750 Sport Oil screener Posted: Tue Apr 24, 2018 8:50 am |
Thanks a lot for ideas!  Got it out
| Top |
[ 8 posts ] |
Users browsing this forum: No registered users and 1 guest |
