ducatipaso.org :: View topic - 750 Sport Oil screener
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=13&t=7901
Author:  Obito [ Tue Apr 17, 2018 8:48 am ]
Post subject:  750 Sport Oil screener
Hello everybody,
I was making an oil change to my 750S and wanted to clean the oil screener/strainer. I ran into a problem where the strainer part got stuck inside the engine and only the bolt came out. Is there any hints how to get it out?
File comment: Oil screener
Author:  paso750 [ Wed Apr 18, 2018 7:45 am ]
Post subject:  Re: 750 Sport Oil screener
Ups. It happens sometimes and it happened to a few guys on the forum. I guess the only way to get it out is with a lot of patience and long needle nose pliers.
Author:  Derek [ Wed Apr 18, 2018 8:31 am ]
Or maybe a pair of artery forceps
Author:  Obito [ Fri Apr 20, 2018 6:16 am ]
Thank you for the hints. I have to try this...
Author:  Derek [ Fri Apr 20, 2018 8:23 am ]
Another option:
Author:  paso750 [ Fri Apr 20, 2018 9:40 am ]
those are good but not very strong. Since the plastic part he has to fish out has almost the same diameter as the hole it needs to be pulled through it will slip from that grabbing tool every time.
Another thing to try with long needle nose pliers is stick them into the tube carefully and open the pliers while pulling out. Getting it this way might make it easier pulling it out than grabbing its edge. If the pliers are too big one could also unbend a coat hanger, shape a U, bend the tips outwards and use it the same way.
Author:  Derek [ Sat Apr 21, 2018 8:02 am ]
Author:  Obito [ Tue Apr 24, 2018 8:50 am ]
Thanks a lot for ideas! :) Got it out
Page 1 of 1 All times are UTC
http://www.phpbb.com/
