ducatipaso.org :: View topic - Gas leakage from carb, 750s
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=13&t=7920
Author:  Obito [ Thu May 31, 2018 6:17 pm ]
Post subject:  Gas leakage from carb, 750s
What is this part of carb and how can I prevent it from leakage? When turning the gas handle this part moves and starts to drip a little gas over time...
Author:  paso750 [ Thu May 31, 2018 8:26 pm ]
Post subject:  Re: Gas leakage from carb, 750s
That's the accelerator pump. There's a membrane behind the cover that may need to be replaced.
Author:  higgy [ Fri Jun 01, 2018 10:58 am ]
http://stores.ebay.com/ALFA1750S-CARBUR ... ORE?_rdc=1
https://www.ebay.com/itm/WEBER-40-42-44 ... 43a165f925
Author:  Obito [ Fri Jun 01, 2018 2:21 pm ]
Got one from local bike part seller. Hopefully it is the right part :)
Author:  higgy [ Fri Jun 01, 2018 7:19 pm ]
All Weber DCNF's use the same one
Author:  Obito [ Fri Jun 01, 2018 7:22 pm ]
That fixed it! Great, once again thanks to you guys :)
This also fixed the rushing issue and bad idle running I had in my other post.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
