It is currently Fri Mar 06, 2026 5:41 pm
 Post subject: Member presentation
PostPosted: Sat Dec 08, 2018 11:58 am
Hi
A few words to introduce myself.
I joined this great forum many years back when I bought my Sport. An accident put a pause in my plans in 2011 and it is only now that I havet time to get the repair started.
Was thinking to give something back to you all in the forum who so kindly support the rest of us with your knowledge by sharing the repair work as it progresses.
One question though: what is the best (and cheapest) way to insert pictures in this forum?
Kind regards
Petrus/ Sweden
750Sport -88 (undergoing surgery)
Pantah racer
450D mk3 -69
900SSie -02
 Post subject: Re: Member presentation
PostPosted: Sat Dec 08, 2018 2:36 pm
Hi there,
the easiest is to add them to your post. Ideally the pictures are not bigger than 1024x786.
Below the editing window you'll find 'Filename' and 'Add file'. Chose the picture from your computer and click 'Add the file'. After that submit your post.
If more than one picture are uploaded they will show in reverse order. The one you added first will be the last one in your post. Give it a try.
PostPosted: Sun Dec 09, 2018 7:11 am
Thanks for the quick response.
Did not see the function to add pic since I was on my mobile. But now I found it. Thank you.
So here is a pic of me having a break
Edit: Did not succeed. Will try later from my computer...
Pantah racer
450D mk3 -69
900SSie -02
