| Idling at 3000 rpm after a hard run http://ducatipaso.org/forum/viewtopic.php?f=13&t=8110 |
| Author: | steveT2 [ Thu Apr 18, 2019 9:56 am ] |
| Post subject: | Idling at 3000 rpm after a hard run |
Just wondering if anyone as encountered a high idle after putting there bike through its paces. It’s fitted with the standard Webber carb. A brief rundown, I ended up doing around 40 miles in fast company all was OK until the return home, redlined through the gears coming onto a duel carriage way, then a 70mph cruise all was ok, showed for the rouderbout and noticed it idling around 3000 rpm, carried on, fine at a steady 60-70mph and on full throttle but still inflicted with the high idle, got home let it idle for a while with the odd blip on the throttle and it seemed to wonder between 2-3000 rpm, started it for a short while this morning and it’s idling around 1200rpm, I haven’t had chance yet to give it another run to see if the high idle returns. Any thoughts Steve |
| Author: | randtcastell [ Thu Apr 18, 2019 3:46 pm ] |
| Post subject: | Re: Idling at 3000 rpm after a hard run |
I had a similar condition recently and after looking for vacuum leaks, cracked rubber boots, loose intake manifold bolts, worn/dirty spark plugs, carb sychronization, etc, the problem turned out to be throttle cables: sticking a little on return. Lubing the cable and throttle with white lithium solved my issue. Good luck resolving yours. :-) |
| Author: | 1989750Sport [ Wed May 01, 2019 9:05 pm ] |
Hi, I had a similar occurrence. It happened when I was parking the bike after a long ride. I was turning into the parkimg spot and was hitting the steering lock; that seemed to slightly open the throttle and keep it there. The problem resolved when I rerouted the throttle cable. Hope this helps! P.S. Any idea how to make photos small enough to post on this site? |
