It is currently Mon Apr 13, 2026 8:24 am
[ 3 posts ] |
| Author |
steveT2
Post subject: Idling at 3000 rpm after a hard run Posted: Thu Apr 18, 2019 9:56 am |
Joined: Thu May 05, 2016 7:37 am Posts: 65 Location: UK
Just wondering if anyone as encountered a high idle after putting there bike through its paces. It’s fitted with the standard Webber carb. A brief rundown, I ended up doing around 40 miles in fast company all was OK until the return home, redlined through the gears coming onto a duel carriage way, then a 70mph cruise all was ok, showed for the rouderbout and noticed it idling around 3000 rpm, carried on, fine at a steady 60-70mph and on full throttle but still inflicted with the high idle, got home let it idle for a while with the odd blip on the throttle and it seemed to wonder between 2-3000 rpm, started it for a short while this morning and it’s idling around 1200rpm, I haven’t had chance yet to give it another run to see if the high idle returns. Any thoughts Steve
| Top |
randtcastell
Post subject: Re: Idling at 3000 rpm after a hard run Posted: Thu Apr 18, 2019 3:46 pm |
Joined: Fri Nov 13, 2009 4:33 pm Posts: 317 Location: San Francisco Bay, California USA
I had a similar condition recently and after looking for vacuum leaks, cracked rubber boots, loose intake manifold bolts, worn/dirty spark plugs, carb sychronization, etc, the problem turned out to be throttle cables: sticking a little on return. Lubing the cable and throttle with white lithium solved my issue. Good luck resolving yours. :-)
| Top |
1989750Sport
Post subject: Re: Idling at 3000 rpm after a hard run Posted: Wed May 01, 2019 9:05 pm |
Joined: Thu Nov 02, 2017 12:16 am Posts: 50 Location: UK
Hi, I had a similar occurrence. It happened when I was parking the bike after a long ride. I was turning into the parkimg spot and was hitting the steering lock; that seemed to slightly open the throttle and keep it there. The problem resolved when I rerouted the throttle cable. Hope this helps!
P.S. Any idea how to make photos small enough to post on this site?
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 1 guest |
