| fuel pressure regulator http://ducatipaso.org/forum/viewtopic.php?f=13&t=8175 |
| Author: | jimg1au [ Sun Sep 08, 2019 12:25 am ] |
| Post subject: | fuel pressure regulator |
hi whet regulator should I get for my 750 sport with webber carby also what should I look for to get gasket kit and new needle and seat my carby floods plugs are always black thanks jim |
| Author: | paso750 [ Tue Sep 10, 2019 9:15 am ] |
| Post subject: | Re: fuel pressure regulator |
It shouldn't be a problem finding a gasket kit. The only difficulty I had some time ago is getting the thick gasket that sits between carb and carb manifold. Is there an Y-piece in the fuel line with a return to the tank? There should be. If there is there will be a 120 Dellorto jet in the Y-piece's exit returning to the tank. You could try to remove the jet and/or turn around the Y-piece so it splits towards the carb and the tank return. Maybe this will be enough to reduce fuel pressure. If you get a fuel pressure regulator it should be one with 3psi max. |
