ducatipaso.org • View topic - Clutch springs
It is currently Sat Jun 13, 2026 5:35 am
 Post subject: Clutch springs
PostPosted: Wed Nov 06, 2019 10:20 pm
Can anyone enlighten me on the tightening process of the new clutch springs in my 89 900 supersport, do the bolts get screwed down to the posts on the pressure plate? Do these get threadlock? Any help appreciated cheers
 Post subject: Re: Clutch springs
PostPosted: Thu Nov 07, 2019 9:58 am
I assume that it is the same as all the other Ducati dry clutches. The posts are easily broken off. Just nip the bolts down until they are snug and don't use threadlock, the springs will prevent them from loosening.
PostPosted: Thu Nov 07, 2019 9:28 pm
Thanks Derek, a lots gone into bringing this clutch back to life I don't want to get it wrong at this stage, compressing the springs so much just seemed unnatural, you've put my mind at ease, have a good one
PostPosted: Sat Apr 04, 2020 5:37 am
The screws get tightened all the way down, but do so gradually in a hex pattern, tightening a few millimeters at a time. The screws are 8 nm, if you need a torque figure.
Users browsing this forum: No registered users and 44 guests
