| Rear brake pump leaking - 750 Sport http://ducatipaso.org/forum/viewtopic.php?f=13&t=8418 |
| Author: | Desmo Tutu [ Mon Sep 06, 2021 7:56 pm ] |
| Post subject: | Rear brake pump leaking - 750 Sport |
My 750 Sport is leaking from the rear brake pump. Easily fixed with the 0664339732 replacing set. But that seems to be long gone. Same with a complete pump 066441300. My ducati dealer suggest I could try a later pump 62540041A, but they have the brake line from the side/top, not from the end as my original pump. I would appreciate any help/link etc to the correct replacement part, if that is a replacement set or a complete pump. |
| Author: | paso750 [ Tue Sep 07, 2021 10:19 am ] |
| Post subject: | Re: Rear brake pump leaking - 750 Sport |
Your dealer is suggesting a brake pump with 40mm mounting hole distance to replace one with 50mm? I'm not sure if the original was a PS11 or 12, but Stein Dinse has the first: https://www.stein-dinse.biz/product_inf ... rettyPhoto |
