ducatipaso.org • View topic - routine maintence paso 906
It is currently Mon Sep 29, 2025 5:22 am
 Post subject: routine maintence paso 906
PostPosted: Thu Aug 09, 2007 12:54 pm
Hello Paso Fans,
in which intervalls do you check valve clearance, belt tenion, and
renew engine oil on your Paso 906? I did it every 5.000 km, but I
found out that the owner's manuel wants you to do that every 3.000 km. Do I save on the wrong end? Do you have any experiene concerning routine maintence on a 1990 Paso 906?
Thanks a lot for your input and keep on riding,
Hardo
PostPosted: Thu Aug 09, 2007 4:01 pm
Hi, 5000 km for the manual, but I never met a duc that needs such a short interval for tension and clearance check.
The only REAL interval is 12000 miles /20000 kms for belt changing :eek:
Someone (like finnpaso) says that pasos need a very lighter maintenance than desmoquattro engines :D
The manual gave me the lagest past of suggestion I need for maintenance and various sites tells you how to change belts.
Of course it's not the everyday "do-it-yourself" job, such as painting a door! :evil:
PostPosted: Thu Aug 09, 2007 4:28 pm
Hola:
I did everything indicated in the Paso user manual after the first 3.000 km but, after that, I have followed my "instinct":
- Valve clearance and belt tension adjustment every 10.000 km, approximately.
- Oil replacement every 5.000 km.
According to my old local dealer (the one I bought my 906 in 1990!), the belt should last without any problems for more than 40.000 km, but I think this is like playing with fire. I changed first mine with 30.000 km but I think is much better to follow the recommendations of the manual to be in the safe side, as Nicola indicates.
Regards.
Luis Javier
PostPosted: Fri Aug 10, 2007 10:15 am
Thanks a lot for your input! :thumbup: Hardo
PostPosted: Sat Aug 11, 2007 10:18 am
PostPosted: Sat Aug 11, 2007 9:37 pm
15W-50 fits better to Ducati engine, especially to gearbox... :evil: Those, who here have started to use 15W-50 in they Ducatis, dont want to go back anymore to lighter stuff.... Me also! Shell Advance Ultra 4 15W-50. :thumbup: And oil change every 5000kms WITH new filter! But surely everybody think this "oil" little different way, so no need to make here "big war" about it, I think, if be happy, then no need to change to different oil. :D
