ducatipaso.org • View topic - Odometer wire
It is currently Fri Nov 14, 2025 3:05 am
 Post subject: Odometer wire
PostPosted: Tue Oct 30, 2007 7:06 pm
PostPosted: Wed Oct 31, 2007 1:47 pm
I heard to say that it's the same installed on more recent aprilia 125 rs, but you must be sure that's clockwise (to be installed on the left side of the wheel) and that the ratio mark imrpessed on the alloy part matches (this might be 11/21, but I'm not sure, you should see on your one)
PostPosted: Wed Oct 31, 2007 1:57 pm
If it is just the speedometer cable (the one that goes from the geared housing on the axle by the wheel and runs up to the instrument cluster), they may still be available through Ducati. If it is the same as a Paso 750, the part number is 037038710. Your local Ducati dealer will know any superceded part numbers.
If just the internal cable broke and the housing is fine, you can sometimes cut down another cable to the proper length. There may be some places that can make the internal cable for you. The cut end will have to be squared off to run the gear.
There's always eBay, also. I've seen a few, from time to time, and they usually go fairly cheap, as there is little demand for them.
I wish you luck! :thumbup:
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu Nov 01, 2007 1:49 pm
Most any auto parts store sell a universal kit to replace inner cable, less than $10 US. Have used on 907 and last week on my El Camino.
PostPosted: Thu Nov 01, 2007 11:19 pm
Thank you.I'm not at home this week,so I can't check if it is only the inner wire or the whole thing,but next week I'll check and tell you what i did.
