ducatipaso.org • View topic - Paso cam timing
It is currently Fri Oct 30, 2026 5:11 am
 Post subject: Paso cam timing
PostPosted: Sat Feb 23, 2008 11:28 am
Given that the 906 Paso has a cam timing that is quite 'soft', has anyone tried putting a set of 900ss cams to the 906 engine? They have the same lift for inlet and exhaust but longer duration.
 Post subject: Re: Paso cam timing
PostPosted: Sat Feb 23, 2008 12:40 pm
States here http://www.moto-one.com.au/performance/duccamspec.html that same cams in SS, 906, 907.
PostPosted: Tue Feb 26, 2008 5:20 pm
Nope, as per my 906 instruction manual the 906 has an inlet/ exhaust timing of :
Inlet 20/60 Exhaust 58/20 (excluding Swiss model)
But the spec for a 1997 900ss is inlet/ exhaust timing: Inlet 24/70
Exhaust 59/29 see the next link (Andres Ducati 900ss homepage)
http://mysite.mweb.co.za/residents/an000003/ele2.jpg
Furthermore there is an article within this very website from performance bikes that states the the 906 cam timing is the softest tune from Ducati yet (1989).
http://ducatipaso.org/docs/906/articles ... -03-89.zip
So according to my information it would appear that the 906 has a softer tune than a 900ss.
PostPosted: Tue Feb 26, 2008 7:50 pm
Ducati belt-drive two-valve twins restoration and modification guide states:
906/907ie/900SS/E900/M900....................20°/60°...58°/20°
900SS (1994-1996).................................43°/85°...82°/46°
900 SS FE (1997-98)/M900S (1998-99)..........24°/70°...58°/29°
900SS (1998-)/M900 (2000)......................25°/75°...66°/28°
so it depends on the year.
PostPosted: Wed Feb 27, 2008 1:03 am
PostPosted: Wed Feb 27, 2008 9:35 am
PostPosted: Wed Feb 27, 2008 9:44 am
PostPosted: Wed Feb 27, 2008 1:15 pm
Hmm, wonder which ones give the most power?
PostPosted: Thu Feb 28, 2008 3:15 am
On the 2V 900, alot seems dependant on manifold lenght:
http://www.visi.com/~moperfserv/carbs.htm
PostPosted: Wed Mar 05, 2008 10:54 pm
ST2 cams are supposed to be the hot setup for the 900SS.
PostPosted: Thu Mar 06, 2008 8:58 am
They are also very good choise to 907IE engine... :thumbup: :smoke:
