ducatipaso.org • View topic - head steering bearing
It is currently Fri Nov 14, 2025 6:41 am
 Post subject: head steering bearing
PostPosted: Sat Mar 08, 2008 3:26 am
hi, does anybody know where can find the head steering bearing for 906 ? :thanks
 Post subject: Re: head steering bearing
PostPosted: Sat Mar 08, 2008 10:34 am
from your Duc dealer :) no, honestly were are you located ?
On the bottom right of the SKF homepage you`ll find a list of distributors selling to end customers:
http://www.skf.com/portal/skf_us/home
If you are in Europe and not knowing if the seller will ship outside Germany, this would be a good deal:
http://cgi.ebay.com/2-x-Kugellager-Kege ... dZViewItem
PS: a few days ago I made a summary of bearings in the P750 FAQ
 Post subject: Bearing code
PostPosted: Sat Mar 08, 2008 1:45 pm
The code for the steering head bearing is 32005X-90KA1. The cones will come out with a pin punch but you will need an angle grinder to cut off the bottom bearing.
PostPosted: Sat Mar 08, 2008 7:47 pm
PostPosted: Sun Mar 09, 2008 4:36 pm
The bottom race can be a PIA. If it's hard to remove then cutting a slot in it will make it slide right off.
