It is currently Fri Nov 14, 2025 5:55 am
[ 8 posts ] |
| Author |
Colonial Boy
Post subject: Dual Headlight conversion question Posted: Wed Mar 03, 2010 7:02 pm |
Joined: Sun Jun 28, 2009 7:18 am Posts: 111 Location: New Zealand
Am I right in thinking an FZ750 headlight from USA or Europe will dip the wrong way for UK (and NZ) and if so is there any way to change this?
CB
_________________ Ducati 906 Paso Kawasaki GPZ900R Triumph Sprint 955
| Top |
persempre907
Post subject: Re: Dual Headlight conversion question Posted: Wed Mar 03, 2010 7:09 pm |
| paso grand pooh-bah |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
You're right. Ciao
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
| Top |
Colonial Boy
Post subject: Re: Dual Headlight conversion question Posted: Wed Mar 03, 2010 9:03 pm |
| Top |
redpaso
Post subject: Re: Dual Headlight conversion question Posted: Mon Mar 15, 2010 12:31 am |
Joined: Sun Feb 20, 2005 12:00 am Posts: 654 Location: Land of OZ (traylia that is) Troy Bayliss Country
I am in the land of OZ & have a US sourced FZ750 dual headlight & the light spread is actually pretty even & causes no issue at all. I would not be concerned about where you source the headlight. It is a definate improvement on the original & worth doing the modification.
_________________ Redpaso "My favourite peice of Ballet is a long sweeping corner"
| Top |
Colonial Boy
Post subject: Re: Dual Headlight conversion question Posted: Mon Mar 15, 2010 4:34 am |
| Top |
Post subject: Re: Dual Headlight conversion question Posted: Mon Mar 15, 2010 10:15 am |
CB The whole assembly is somewhat adjustable,.most likely you will need to shim it to get the angle up high enough. Easy enough to do. With either the H4 or HID it is a big improvement. Higgy
| Top |
redpaso
Post subject: Re: Dual Headlight conversion question Posted: Mon Mar 15, 2010 10:16 pm |
CB from memory both lights have good adjustment in them, I am happy to ride at night now which I would not do before I fitted it as there was more light projected from a 1 year olds birthday cake. I have one set up for high & one for low beam which works a treat, when I get round to it I will fit a switch so I can run both on hi/low for night & just one hi/low for day use. I am also running h4 xenon bulbs 55/60 which are great giving extra light without drawing extra power, (something we Paso owners are very conscious of)
| Top |
blazing928
Post subject: Re: Dual Headlight conversion question Posted: Thu May 27, 2010 6:42 am |
Joined: Tue Sep 15, 2009 4:08 am Posts: 222 Location: Melbourne Vic, Australia
Jaycar have a dual HID conversion AUD$149, brand 'response' Would be perfect!
I have installed a set on my 907, amazing white light, only 30w current draw, but as I only use 1 globe the other half of the loom is doing nothing. I need to use a LED for the parking light as there is yellow glow around the edge from the park globe.
_________________ Nigel
91 907IE - full restoration 91 907IE Red, Wilbers, Staintune Conti, Corbin, MPL Slipper,Ceramic exhaust Lambretta LI150 S3 87 928S4
| Top |
[ 8 posts ] |
Users browsing this forum: No registered users and 2 guests |
