It is currently Wed Oct 01, 2025 3:00 am
 Post subject: ducati paso 906cc 1990
PostPosted: Sat Aug 21, 2010 1:48 pm
just 9000 miles and is hard put in neutral wend is running, any idea for fix this problem? :cry: :cry: :cry: :cry:
 Post subject: Re: ducati paso 906cc 1990
PostPosted: Sat Aug 21, 2010 2:11 pm
Could it be that your idle is set too high?
PostPosted: Sun Aug 22, 2010 7:49 am
A good bleeding of the hidraulic circuit :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: .
Very common on Pasos.
PostPosted: Sun Aug 22, 2010 11:32 am
chain tension and clutch bleeding would be the first two items to check.Going a little deeper it is also very common for the under the cover part of the linkage to need centering but this is more likely to present as missed shifts in the 4 to 5 or 5 to 6 shift. Trouble shifting to neutral is air in the clutch or chain too tight.
PostPosted: Tue Aug 24, 2010 3:05 am
:shock: Thanks guys for your help,i' m going to check for try to find my problem.
