ducatipaso.org • View topic - Rear Footpeg fix
It is currently Wed Oct 28, 2026 8:09 pm
 Post subject: Rear Footpeg fix
PostPosted: Sun Jan 13, 2013 2:44 am
Hello people. I went for a ride on the Paso the other day and noticed that the passenger pegs are not staying up when not in use they vibrate down within a minute of start up, is there any fix for this. This is the first time i have ridden this year and they were not a problem last year. It has just started to happen. Thanks in advance for any tips or tricks.
 Post subject: Re: Rear Footpeg fix
PostPosted: Sun Jan 13, 2013 5:16 am
They are held up by a spring loaded ball that locates the peg . Pull it to bits and clean all the crap out , and I put mine back together with really stiff grease ( like tar twere ) . If they are really floppy the pivot holes can be drilled/filed to fit a larger pin ( 11/32" ) , as can the locating bearing hole , same for the main pegs . If they are getting a bit saggy/ loose its well worth the effort. Check also where the peg bears against the bracket ..... sometimes a few wacks with a hammer ( dissassemble 1st ...... the peg not the hammer ) can reshape the ally so as to reduce the sag. If you do try to reshape ally make sure you have the work well anchored and use a large punch . By placing the end of the punch on the lump you want to flatten your gauranteed of actually hitting the bit you want .... not the bit next to it :D . If you make cleaning / regreasing a yearly event you will drastically reduce the wear in the pivot holes
PostPosted: Sun Jan 13, 2013 7:43 am
Thanks Mc Tool that will be the project in the morning while im waiting out a cyclone here in WA cheers
PostPosted: Sun Jan 13, 2013 7:50 am
PostPosted: Mon Jan 14, 2013 9:02 pm
If the detent ball is completely knackered, bring the parts to a decent bicycle shop and they will get you a ball bearing that will fit.
Like McTool said, take it apart, clean it up, pack it with thick waterproof grease to have it live a long and happy life. Don't spray the footpeg pivot directly with water when cleaning.
PostPosted: Tue Jan 15, 2013 1:44 am
