ducatipaso.org • View topic - coil mounting
It is currently Tue Oct 27, 2026 1:36 pm
 Post subject: coil mounting
PostPosted: Sat Apr 20, 2013 2:48 pm
Hello everyone,
I am back at it again, trying to make my Paso more reliable and failing miserably :,(
I was taking off the rear cylinder coil to clean the ground and the one bolt snapped on its way out. I drilled and tried the trusted easy out,which snapped. :mad:
I tried drilling the easy out,with no luck. :oops:
Where are you fellow Paso owners mounting the coil at where you get a good ground with little effort? (ie-drilling into frame? :wacko:
Thanks a ton and keep the rubber side down! :thumbup:
Rich
 Post subject: Re: coil mounting
PostPosted: Sun Apr 21, 2013 12:38 am
you need a product caller rescuebit,made for drilling out broken taps and extrators
here in the US a 1/8 double ended Rescuebit goes for about 40USD but it will drill into the broken extractor and allow you to ream out the rest
PostPosted: Sun Apr 21, 2013 9:56 am
