ducatipaso.org • View topic - Fitting a RR51 Regulator/Rectifier to a 906 ?
It is currently Wed Oct 28, 2026 3:34 am
 Post subject: Fitting a RR51 Regulator/Rectifier to a 906 ?
PostPosted: Wed Sep 18, 2013 2:51 pm
I know that there is a huge amount of knowledge out there with all you members and hope that some of you can help me out with this problem that I have.
I have had charging problems and have bought a RR51 from ElectrexWorld but am confused as to how to connect it !!
I assume that my bike has an alternator with 3 output cables (diagram2)
BUT
The original unit has 2x Yellow wires, 2x Red wires, 1x White wire and 1x Black wire.
This connects into the loom by a block where both of the Yellow wires each become Pink;
the first Red becomes a Red with Black line AND an Orange with a Red line;
the second Red continues as a Red cable;
the White becomes a Blue;
and the Black becomes a Brown.
I am affraid that I am very confused about this.
I think that the 2 x Pink wires are from the alternator, together with the Red one?
The Brown appears to be from a fuse and assume that this is replaced by the new Red to the battery ?
The Blue, Red/Black and the Orange/Red appear to all lead to the instrument panel.
Can anyone give me advice on these and what should be connected to which wire.????
Grateful for any advice Guys.
:banghead:
 Post subject: Re: Fitting a RR51 Regulator/Rectifier to a 906 ?
PostPosted: Wed Sep 18, 2013 3:47 pm
First thing you need to do is check your stator for shorts or opens with an ohmmeter
see this thread
PostPosted: Wed Sep 18, 2013 3:50 pm
PostPosted: Wed Sep 18, 2013 5:16 pm
Thank you very much.
This is just the information that I need.
I assume that the Red/Black and the Orange wires are replaced by the RR51 Red and Green being connected directly to the battery terminals and can therefore be taped up or removed/disconnected?
:thumbup:
