ducatipaso.org • View topic - Cush drive/carrier removal
It is currently Wed Oct 28, 2026 3:20 am
 Post subject: Cush drive/carrier removal
PostPosted: Sat Apr 22, 2017 6:54 am
While searching for threads about chain lengths, found references to loose sprocket bolts...I have replaced all 5 bolts with shouldered 12.9 ones, but didn't change the lock nuts. Bike is still being worked on.... How do I remove the cush drive carrier? manual just shows an expanded view of the wheel...
also ordered some nord self locking washers...
 Post subject: Re: Cush drive/carrier removal
PostPosted: Sun Apr 23, 2017 9:44 am
the carrier is just stuck in place. When the wheel is removed just pull on the sprocket and the whole thing will come off the rim.
PostPosted: Sun Apr 23, 2017 1:55 pm
that easy!!!!!
PostPosted: Tue Apr 25, 2017 10:36 am
Just as Paso750 says above, cush drive came out nice and easy, plan to replace sprocket lock nuts with aircraft spec stainless ones.....despite these minor set backs I am really enjoying working on my Duc with this forums help and looking forward to getting back on the road for the summer.... :D
http://www.ebay.co.uk/itm/381998205564? ... EBIDX%3AIT
