ducatipaso.org • View topic - The Squish
It is currently Mon Sep 29, 2025 10:20 am
 Post subject: The Squish
PostPosted: Wed Nov 11, 2009 11:25 am
Hi All
I'm at the stage of my rebuild where I'm ready to fit the barrels & heads.Is it necessary to measure the squish and if so,what should it be for a standard 906 motor.I have searched the forum & manuals but there is little information on the subject.
 Post subject: Re: The Squish
PostPosted: Wed Nov 11, 2009 12:44 pm
1,0 mm is usually recommended as optimal & safe w standard conrods.
PostPosted: Thu Nov 12, 2009 9:25 am
Thanks Gert.
So far I've measured the vertical cylinder using some soft solder and it has 1.36mm clearance.
This is the first time I've dealt with this issue.Is 0.36 mm worth worrying about?
PostPosted: Thu Nov 12, 2009 8:07 pm
Got this link from jcslocum when i rebuildt my top end.
http://www.ducatitech.com/2v/maint/rebu ... dwork.html
PostPosted: Thu Nov 12, 2009 10:47 pm
PostPosted: Fri Nov 13, 2009 1:31 am
It wont run bad w 1,36mm squish, most Ducs have that from factory.
Just if you want to blueprint measures, around 1,0mm is close to optimum.
A good idea is to have same figures on both cyls.
PostPosted: Fri Nov 13, 2009 2:25 am
very clean looking pic, Nice work :thumbup:
PostPosted: Sat Nov 14, 2009 3:21 am
PostPosted: Wed Nov 25, 2009 2:46 pm
PostPosted: Thu Nov 26, 2009 5:31 am
