ducatipaso.org • View topic - starter sprag bearing
It is currently Fri Oct 30, 2026 6:02 am
 Post subject: starter sprag bearing
PostPosted: Sun Oct 22, 2006 8:37 pm
PostPosted: Sun Oct 22, 2006 10:13 pm
PostPosted: Mon Oct 23, 2006 12:16 am
PostPosted: Mon Oct 23, 2006 12:12 pm
 Post subject: Re: starter sprag bearing
PostPosted: Sat Jan 19, 2008 11:49 pm
the 906 Paso, 900ss, Pantah engine starter sprag clutch is the same as an LC4 Freewheel bearing (KTM Part No.58440026000), avaliable from your local KTM dealer. I just fitted one of these to my 906 Paso. It is identical to the original ducati part and it cost less than half the price.
duckboy
PostPosted: Sun Jan 20, 2008 8:27 am
Very good!!!
That stuff have to be put in the interchange topic.
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Sun Jan 20, 2008 10:59 am
Great to know, duckboy, thx f sharing! :thumbup:
PostPosted: Tue Jan 22, 2008 9:51 am
In my ST4S free clutch went broken(year ago) and i bought KTM part(cant remember now ordering number), but i had to use ONLY those "friction pieces"(and spring) from new KTM OEM part, cause they "holder"(frame) was different, but that is only in my ST4S. Remembering, that KTM part will fit to older modell Ducatis, but not "direct" to newer modells. Anyway my "friction pieces" went too bad condition and also that spring was totally too loose, so KTM part helped me enough... :smoke: Ps. remembering, that KTM part was something about 60€....
PostPosted: Tue Jan 22, 2008 10:28 am
i have read since posting the original article that instead of replacing the bearing, simply shortening the spring may work. unscrew the spring apart, cut about 25mm off the tail of it (the thick end) screw it back together, and refit it (don't try to pull the ends apart or you will loose the tension on the spring). oh well... i'll just have to wait until this one fails, then give that a try.
Duckboy
PostPosted: Wed Jan 23, 2008 10:36 pm
Shortening spring work. Think I shortened mine like 3 times, like 40-50mm in total.
I also machined the little knobs the spring holds together to make them smoother after wear.
I`m replacing it know after 130 000 km`s. But still works on my Monster! :cool:
Regarding interchangeability, a 600 freewheel don`t fit a 900.
PostPosted: Thu Jan 24, 2008 3:07 pm
Cut off thin end, not thick end as this is where you screw thin end into.
PostPosted: Sat Jan 26, 2008 11:44 am
PostPosted: Sat Jan 26, 2008 1:34 pm
