It is currently Mon Sep 29, 2025 4:18 pm
[ 5 posts ] |
Author |
dave906
Post subject: Digiplex Ignition circuit board resolder Posted: Tue Jan 30, 2007 11:45 am |
Joined: Tue Apr 11, 2006 12:00 am Posts: 32 Location: Canberra, Australia
Having some intermittent ignition problems with the Marelli Digiplex when it heats up after a few miles on the road. Having done the relay rewiring mods without completely solving the problem, I am planning on cracking open the Digiplex and resoldering the circuit board next to see if this corrects any dry or cracked solder joints. If this doesn't solve the problem then I'm getting out the English-German dictionary and speaking to Mr Silent Hektik.
The underside of the ignition seems to have a plastic panel that doesn't have any obvious way of removing it - ie no screws. Initial gentle prying with a screwdriver hasn't released it. It may be glued in place.
Before I start hacking away without knowing exactly how its put together or configured underneath the panel, have any of the people who have had their Digiplexes resoldered got any advice on how the panel is best removed? Any tips or photos on what to do and what not to do??
cheers Dave
Top |
Post subject: Posted: Tue Jan 30, 2007 2:05 pm |
paso grand pooh-bah |
Dave,
sure that the heating up isn`t caused by any bad wiring or ground connections ?
Gerhard
Top |
dave906
Post subject: Posted: Wed Jan 31, 2007 12:52 am |
Top |
persempre907
Post subject: Posted: Wed Jan 31, 2007 6:07 am |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
Top |
JWilliam
Post subject: Digiplex Ignition circuit board resolder Posted: Wed Jan 31, 2007 6:33 pm |
Joined: Wed Oct 06, 2004 12:00 am Posts: 327 Location: Nottingham, UK
Try Bauke Meidema's electric relay mod to the ignition unit for one, and I recommend changing the fugin' standard ignition coils for Kawasaki GPZ500 units (greater primary coil impedance - preventing overloading of the ignition unit). Don't know how many times I've said that. The Digiplex unit bottom is glued on, work your way around the edge of this plastic underpanel but be careful not to penetrate the unit, just work off the underpanel. You won't find anything out of the ordinary, but all the components are covered with a rubberised waterproof sealant and it also has an EPROM chip so No BRIGHT LIGHTS. The main fault I have had with the unit is a misfire above 7000rpm, but this was stopped! by changing the ignition coils (see above). Apart from that I am not totally sure about the ignition mapping and I have read that the Silent Hektik module has a number of ignition maps, don't think you will need them unless you campaign it at your local racetrack. Your comment that it is OK until it warms up strikes a chord with the above mentioned coil exchange fix but if this is happening at low rpm then your ignition unit might already be past it.
Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 6 guests |
