1991 906 PASO http://ducatipaso.org/forum/viewtopic.php?f=2&t=1668 |
Page 1 of 2 |
Author: | Rockwellman [ Tue Apr 03, 2007 3:11 pm ] |
Post subject: | 1991 906 PASO |
Author: | paso750 [ Tue Apr 03, 2007 6:52 pm ] |
Post subject: | |
Hi Michael, you connected it according to the wiring diagram ? (P750 and 906 regulators are the same so connections are also) Is it an original or an aftermarket part or of another Duc ? here some links: Gerhard |
Author: | Rockwellman [ Tue Apr 03, 2007 7:35 pm ] |
Post subject: | 906 |
Author: | paso750 [ Tue Apr 03, 2007 7:53 pm ] |
Post subject: | |
Author: | Rockwellman [ Wed Apr 04, 2007 7:18 am ] |
Author: | persempre907 [ Wed Apr 04, 2007 9:10 am ] |
Post subject: | |
Author: | Rockwellman [ Wed Apr 04, 2007 11:38 am ] |
Author: | paso750 [ Wed Apr 04, 2007 5:13 pm ] |
Post subject: | |
Author: | paso750 [ Wed Apr 04, 2007 5:20 pm ] |
Post subject: | |
Author: | Rockwellman [ Wed Apr 04, 2007 7:56 pm ] |
Author: | paso750 [ Thu Apr 05, 2007 6:19 pm ] |
Post subject: | |
Author: | Rockwellman [ Fri Apr 06, 2007 7:49 am ] |
Author: | Rockwellman [ Fri Apr 06, 2007 12:01 pm ] |
Hi G, I took the cover off which houses the alternator to follow the three wires 2 pink and one red. Only the two pink are connected to the alternator, but the wiring diagram on 750 & 906 says that there are three wires connected to the alternator. my workshop manaul does not give a detailed explanation of how and where the red wire is attached? help Thanks Michael |
Author: | paso750 [ Fri Apr 06, 2007 2:08 pm ] |
Post subject: | |
ok, I`ll check on my own bike, just have to see in which box my whole wiring loom is ![]() I`m not sure if there were Pasos with a 2 wire alternator. The 907ie did and also Supersport/Monster did have these. Could also be that someone replaced it once. I assume that your regulator is one with wires coming out of it or one with flat contacts ? If it`s the first there may be 2 yellow and 2 red wires coming out of it plus 2 more, right ? (the 2 red in the middle of the 6 cables). In this case the 2 red cables should join and run towards the battery. I`m just thinking loud, let me take a look first ... Gerhard PS: although already mentioned, ground connection of the regulator housing is very important |
Author: | paso750 [ Fri Apr 06, 2007 8:03 pm ] |
Post subject: | |
ok my wiring loom is of no help as with the aftermarket regulator it`s a bit different. However looking at circuit diagrams of 907ie, Supersport or Monster it shows that the 2 (middle) red wires of the regulator are connected. http://www.box.net/shared/3elasen7q7 Hard to give a recommendation here. As asked in my last post, what kind of regulator is is the old with spade contacts or one with wires coming out of the housing ? G. |
Page 1 of 2 | All times are UTC |
