ducatipaso.org • View topic - 906 repairs / adjustments
It is currently Mon Sep 29, 2025 10:20 am
 Post subject: 906 repairs / adjustments
PostPosted: Tue Jun 12, 2007 3:23 am
PostPosted: Sun Jun 17, 2007 6:23 am
Hi Enzo,
the water leak from the pump is a frequent issue.
It's quite easy fix it: you need only replace the ring on the shaft.
The water pump is the same of the later Ducati, so you wouldn't have any problem to find it.
Unfortunately, I haven't any experience with the Dellorto carbs. I cant' help you.
PostPosted: Sat Jun 23, 2007 7:59 am
Howzit
Welcome to 906 land,once your on top of it dude" she'll be right !bro".The faults are plentiful but are all easily overcome.Most parts [crank ]are shared with 907,851,916,ST2 etc [eg all water cooled models] Couple questions : How you testing for manifold air leaks ??have you set vacuum for ignition unit[assuming you got OEM Magnetti-marreli digiplex unit]
Ducs are very easy to work on if you have a good mechanical mind .Common size hex heads all over .but beware the Italians like 15mm as a bolthead size.
Cheers Andrew
PostPosted: Wed Aug 01, 2007 11:33 pm
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
