| Fan does not stop http://ducatipaso.org/forum/viewtopic.php?f=2&t=1992 |
Page 1 of 2 |
| Author: | hardo [ Mon Sep 17, 2007 12:54 pm ] |
| Post subject: | Fan does not stop |
| Author: | ducapaso [ Mon Sep 17, 2007 4:55 pm ] |
| Post subject: | |
| Author: | JWilliam [ Wed Sep 19, 2007 5:13 pm ] |
I have a fully electronic controller for my fan because I run my Paso with two radiators so have had to ditch the standard bi-metallic switch. The circuit is a modified Velleman thermostat and I can vary the switch on temperature along with the switch on at - switch off at - setting (hysteresis).... But it took a bit of doing. |
| Author: | Finnpaso [ Wed Sep 19, 2007 5:26 pm ] |
| Post subject: | |
"JWilliam": I am very courious, HOW You did it, so can U explane more? :confused: I added to my 907IE 2 extra small fans with normal switch in right handlebar to put more fans on, if driving in hot conditions in cities with low speed. When speed is higher, then it automatically cools engine more, so then i switch off those "extra fans"... |
| Author: | JWilliam [ Thu Sep 20, 2007 9:32 am ] |
Well I wouldn't be running a water cooled 750!, its a 906. When you say you are curious, do you mean the second radiator or just the electronic fan control? |
| Author: | Finnpaso [ Thu Sep 20, 2007 12:21 pm ] |
| Post subject: | |
| Author: | JWilliam [ Fri Sep 21, 2007 12:15 pm ] |
| Author: | Finnpaso [ Fri Sep 21, 2007 12:25 pm ] |
| Post subject: | |
| Author: | ducatipete [ Sun Sep 23, 2007 11:12 am ] |
| Post subject: | |
| Author: | hardo [ Mon Sep 24, 2007 3:22 pm ] |
| Post subject: | |
| Author: | ducatipete [ Mon Sep 24, 2007 6:16 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Mon Sep 24, 2007 6:40 pm ] |
| Post subject: | |
| Author: | ducapaso [ Tue Sep 25, 2007 2:56 pm ] |
| Post subject: | |
| Author: | hardo [ Wed Sep 26, 2007 4:51 pm ] |
| Post subject: | |
Thanks a lot...does anybody know if the temp switch has two electric connections or just one? all the best and keep on riding, hardo |
| Author: | ducapaso [ Fri Sep 28, 2007 3:49 pm ] |
| Post subject: | |
