| Speedo Cable Drive removal? http://ducatipaso.org/forum/viewtopic.php?f=2&t=2078 |
| Author: | kirk332 [ Fri Nov 02, 2007 12:18 pm ] |
| Post subject: | Speedo Cable Drive removal? |
After undoing the retaining nut on the wheel end, should the inner cable just lift out or is their a trick to it? Mine doesn't want to part and I don't want to force it for fear of breaking it. I also noted a spring loaded ball bearing at the bottom. Is this for lubricating purposes? Finally, what do you lubricate the inner cable with please? Cheers |
| Author: | Desmo_Demon [ Fri Nov 02, 2007 1:14 pm ] |
| Post subject: | |
