| Clutch hose routing. http://ducatipaso.org/forum/viewtopic.php?f=2&t=2080 |
| Author: | kirk332 [ Fri Nov 02, 2007 12:45 pm ] |
| Post subject: | Clutch hose routing. |
I have overhauled the clutch pump and slave cylinder and bleed the system. All is working fine however I can't remember which way the hose was routed. Does the hose pass in front of or behind the head stem? I currently have it passing forward of the head stem however it appears that at full left lock the hose rubs more than I think it should. I feel that if I were to make it pass behind the head stem, then at full left lock it would have some fairly big bends on it however I could be wrong. I should have checked it out before bleeding or taken more notice prior to disassembly but!!! Cheers |
| Author: | kirk332 [ Thu Nov 08, 2007 2:11 am ] |
| Post subject: | |
| Author: | Desmo_Demon [ Thu Nov 08, 2007 1:40 pm ] |
| Post subject: | |
| Author: | kirk332 [ Fri Nov 09, 2007 12:47 pm ] |
| Post subject: | |
| Author: | Desmo_Demon [ Fri Nov 09, 2007 1:38 pm ] |
| Post subject: | |
| Author: | kirk332 [ Sat Nov 10, 2007 3:04 am ] |
| Post subject: | |
