| 906 Tech FAQ http://ducatipaso.org/forum/viewtopic.php?f=2&t=2194 |
| Author: | jcslocum [ Sat Dec 15, 2007 2:45 am ] |
| Post subject: | 906 Tech FAQ |
I think it's time that we built a 906 specific technical FAQ-thread the way we have been building one in the 750 forum. I'm by no means a 906 expert but can troll thru the threads to find what I think might be important but it's the users of the forum that really know what's unique and needed to populate this FAQ. Please add the past threads that you think will be most useful for others. DO NOT ADD NEW QUESTIONS IN THIS THREAD Buying a Paso: viewtopic.php?f=1&t=705 Voltage Regulator Issues: viewtopic.php?f=2&t=1959 |
| Author: | jcslocum [ Sat Dec 15, 2007 2:57 am ] |
| Post subject: | Re: 906 Tech Faq |
Paint codes viewtopic.php?f=2&t=1498 |
| Author: | paso750 [ Sat Dec 15, 2007 7:04 pm ] |
| Post subject: | Re: 906 Tech FAQ |
Workshop manual and other downloads: Note: if you follow one of the links below and then click on the download button you may get a 'register'/'log-in' pop-up. Ignore that. Just wait a second and you'll get a message from your webbrowser asking if you want to open or download the file. P906 owner`s manual US version P906 workshop manual P906 parts catalogue P906 wiring diagram (in colour) P906 wiring modifications Weber mod and jetting for the P906 coolant reservoir modification TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires) other downloads, reviews, magazine articles etc. viewtopic.php?f=1&t=1551 Paso 750 FAQs you will find a lot more info there! I.e. alternative clutch slave piston, master cylinder rebuild etc. viewtopic.php?f=1&t=705 |
| Author: | jcslocum [ Thu Oct 16, 2008 10:51 am ] |
Repair of the Digiplex ECU viewtopic.php?f=2&t=2813 |
| Author: | jcslocum [ Fri Feb 27, 2009 6:39 pm ] |
Weber Carb Jetting viewtopic.php?f=2&t=3090 |
| Author: | paso750 [ Wed May 20, 2009 8:55 am ] |
Connecting an ELECTREX regulator/rectifier: Electrex to original wiring yellow -> both pink (alternator) yellow -> red (alternator) white -> light blue (charging warning light) red -> red/black & orange (battery +) green -> black (battery -) (the brown wire of the Paso wiring loom formely going to the regulator is not used any longer) Note: If the measured voltage between the two yellow wires from the alternator (which are pink when they get to the regulator/rectifier) is between 50-100V you should wire the reg/rect as shown on the first picture of the instructions hence connect yellow 1 from the reg/rect to one yellow(pink) wire from the alternator and yellow 2 to the other. In this case the red wire from the alternator isn`t used and can be isolated. Install like this if the first wiring instructions don`t work. (To check simply connect a voltmeter to the battery. When the engine is started and the regulator/rectifier is connected correctly the voltage will increase i.e. from 12V to ca. 14V) https://app.box.com/s/r16ixjegwfl7aq3ybd0c |
| Author: | jcslocum [ Sun Jan 10, 2010 10:12 pm ] |
Seat moving back and forth Fix viewtopic.php?f=2&t=3846 |
| Author: | paso750 [ Sat Oct 16, 2010 10:18 am ] |
Engine bearings & seals viewtopic.php?f=2&t=4369 |
| Author: | paso750 [ Mon Oct 14, 2013 9:12 am ] |
Using an AFR meter for carb setup viewtopic.php?f=2&t=6403 |
| Author: | paso750 [ Mon Dec 02, 2013 5:25 pm ] |
906 wiring mods https://app.box.com/s/xzkocz2e7zcomsg40t7f |
| Author: | paso750 [ Sat Feb 28, 2015 6:28 pm ] |
Conrod small end bush viewtopic.php?f=13&t=6839 |
| Author: | paso750 [ Fri May 01, 2015 8:08 pm ] |
Clutch piston for the 906s with the clutch piston in the clutch cover (not the later ones that have it on the left engine side) viewtopic.php?f=2&t=7124&p=56530#p56530 |
| Author: | paso750 [ Sun Jul 19, 2015 7:40 am ] |
service bulletin gear selector mechanism - all Ducati https://app.box.com/s/ccqi4o1hoelpn458dffawwf51kiq20cs |
| Author: | paso750 [ Fri Sep 23, 2016 8:41 am ] |
Thermostat repair viewtopic.php?f=2&t=7515 viewtopic.php?f=3&t=7884&p=61738&hilit=thermostat#p61738 |
