ducatipaso.org • View topic - 906 headlight conversion
It is currently Fri Nov 14, 2025 2:55 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: 906 headlight conversion
PostPosted: Mon Jan 21, 2008 5:25 am
Hi Pasofiles
i am looking at fitting a headlight from a fz 750 with the twin globes (86 to 88 model) to my 88 Paso
given the output (as stated in manual) of the alternator is is 12V-350W, will this have enough power to run both globes (on high beam) as well as the other tasks the electrical system is expected to do? (like run the clock :laugh)
there is already a highbeam relay in place so the extra demand would not be put on the (aging) original wiring harness.
what size (power) globes would i be able to use?
 Post subject: Re: 906 headlight conversion
PostPosted: Mon Jan 21, 2008 5:01 pm
PostPosted: Tue Jan 22, 2008 9:04 pm
Redpaso has posted on this before, has one fitted to his 906,(I believe).
Where are you RED?, off rallying somewhere no doubt! and going hard!
Hopefully he may be able to sort out your query.
..........Marty
PostPosted: Tue Jan 22, 2008 9:41 pm
I remember reading ( I can you know !) in a two wheels mag cicra 1990 that there is a hella light that can be fitted to the paso with little modification. The article even gave a part number ...... which I now cant find ( the wife is a very tidy person, in fact if you stand still to long in our house you are likely to have your top pollished and your bottom vacuumed ! ) I will try to find this # for you as I am sure now that the topic has come up I will need one myself soon
PostPosted: Tue Jan 22, 2008 11:32 pm
HI
I have previously owned an '89 900 ss. when i broke the headlight on that I replaced it with the Hella Halogen insert (part No. 1042), which needed slight modification (eg. secured with duct tape). Apparently the FZ750 unit is an exact mach for the Paso light, and should screw in without modification.
PostPosted: Tue Jan 22, 2008 11:42 pm
Im still looking for someone 'versed in the flow of the electron' to do the math regarding the ability of the wattage output to cope with the photon generation.
:smoke:
PostPosted: Fri Jan 25, 2008 1:51 am
Hi Duckboy what you are looking for is a thing called "Ohm's law " This is a basic formula to calculate the watts , current flow ( measured in amps ) and the resistance ( to current flow, measured in ohms ) This formula can be transposed to calculate any of the components above
Your alternater has an out put of 350 watts , if you divide this by the voltage in the circut ( which is not nessessarily 12v , you will have to use a volt meter to measure this at the battery and should be somewhere between 12v and 14.5v depending on engine speed ) but for arguements sake lets call it 12v , so 350w divided by 12v is 29 amps which is the max load your alt can support . using the same formula we can take 100 watts ( headlight power ) and divide by 12v which give us 8.3 amps so we can see that of the available power from the alt ( 29 amps ) the headlight is giong to need 8.3 of these amps to work . you would need to apply this formula to all of the constsant loads on the elect system ie magic box (ignition module ) ,head and tail lights , fuel pump and coils . Blinkers , brake lights ,horn and charging system are not constant so we can lump them together and call it 5 amps or 60 watts ( 5 amps times 12volts is 60 watts )
To get the wattage of the coils and fuel pump you would need to measure the current ( amps ) to each and the mutiply by 12 volts to give you the watts , Add up all the constant loads , in either watts or amps, add in the 5 amps or 60 watts for the other stuff ( this is a bit of a guestimate ) and as long as this total doesnt exceed the total power output of the alt everything is cool
BUT the higher the load on the system the harder it is on the alt and the voltage regulator / rectifyer and like the motor itself , doesn't pay to run them at the red line all the time so I would limit this total load to 300 watts . In a nut shell the 100 watt headlight is a doddle , but I would abvise the use of a relay and a direct feed to the battery or you may fry the standard light switches
good luck
PostPosted: Fri Jan 25, 2008 7:00 am
PostPosted: Fri Jan 25, 2008 12:47 pm
PostPosted: Fri Jan 25, 2008 1:33 pm
there is enough power in battery to handle all normal stuff, so if some reason battery goes down, then MUST be some faults in system. But in 907 that 350W system is very critical and cant put so much other devices, what use current. 906 is carbied, so there is not such problem. I use allways low beams, when i drive and all function well.....
PostPosted: Sat Jan 26, 2008 11:40 am
PostPosted: Sun Jan 27, 2008 7:36 am
I can tell this: a single 100W bulb gives you more light (expressed in "lumen" ) than a pair of 50w bulbs
PostPosted: Sun Jan 27, 2008 12:12 pm
PostPosted: Mon Jan 28, 2008 9:38 pm
PostPosted: Tue Jan 29, 2008 11:15 am
I guess it`s hard to compare 2 50W bulbs with one 100W if you`re considering the FZ headlight.
As you`re using 2 reflectors with 2 bulbs in the FZ headlight I would assume that the spread of light is larger than with one bulb only. Furthermore I made the experience with the TÜV (vehicle control institute) that the light can worsen if you use stronger bulbs simply because the reflectors and specially the lenses have not been developed to handle such power causing the light output to become diffuse. (but I guess this problem is more when you try to use i.e. HD/Xenon bulbs in a standard headlight)
G:
